Hello Guest it is September 29, 2026, 05:43:11 PM
Author Topic: where can I find the quick keys for a pendant  (Read 15795 times)
Offline josh
  •  101 101
« on: August 16, 2008, 02:40:32 AM »
hello
I am trying to see where I can find all the codes or short cuts for all the keys on my DRO
I am trying to set my pendant where I only pust a button and it will do as what
I tell it to do. but I dont know what to input on the keygraber box.
i know alt-s is for cycle stop
          alt-r is for cycle start
   spacebar is for feedhold
   and ect.........
i hope this made some kind of sence i really dont know how to explain it.
Re: where can I find the quick keys for a pendant
« Reply #1 on: August 16, 2008, 04:44:46 AM »
Have a look in the Customising Mach2 manual, it gives you the info if I remember correctly.
Offline josh
  •  101 101
« Reply #2 on: August 16, 2008, 09:34:40 AM »
iam knew to mach and I have only been using mach3
where would I find mach2 customising manual
« Reply #3 on: August 16, 2008, 09:39:21 AM »
Support tab at the top then documentation then down to Mach2 and you should see the Mach2 customisation manual.
Offline josh
  •  101 101
« Reply #4 on: August 16, 2008, 01:03:39 PM »
thanks finally found it.
« Reply #5 on: August 16, 2008, 01:52:22 PM »
