Hello Guest it is October 22, 2026, 02:43:03 PM
Author Topic: dual x axis direct drive jumpy  (Read 48609 times)
Re: dual x axis direct drive jumpy
« Reply #20 on: August 28, 2008, 11:58:41 AM »
   I to am having the same jumpy problem at low speeds with my X axis using the 4 axis Mechatronics board.
I switched from a Xylotex 4 axis board that ran fine until a lack of proper grounding on my plasma cutter messed it up some how.
The Mechatronics board has a lot of good features so I’m hoping some how we can figure this out. I look forward to watching this forum post
Dzackman
« Reply #21 on: August 29, 2008, 05:39:07 AM »
Solved my problem, it was a loose wire. For anyone else with the motor jitters at low speed, check and check again your wiring.
Dzackman
