Hello Guest it is November 10, 2026, 01:52:52 AM
Author Topic: E-stop VB script  (Read 56736 times)
Re: E-stop VB script
« Reply #10 on: June 06, 2006, 07:10:09 PM »
Try getLED(0) this is the reset LED :)
www.newfangledsolutions.com
www.machsupport.com
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #11 on: June 06, 2006, 08:19:30 PM »
Thank you to Brian Baker,Graham Waterworth and Liquidseek.com for your your help and codes. ;D
I think I got it now.
I would have been done a few hours ago but I found that my Mach 3 install is a little bit off. I'm getting a "Run loop Macro the.." with a "OK" or "Cancel" prompt that was effecting the way Mach 3 is handling the code.
Since this was giving me problems the "getLED(0) and some other codes where not working properly.
Tried the code on my machine computer and works flawlessly. Let me know if you have any problems.
Any suggestion on the Mach 3 problem I'm having, I've reinstalled but the same screen keeps popping up before Mach starts?
One more quick question can we have a wave file play when Mach starts and ends?
Thanks for your Patience and talents ;D
Here is the final code:
Public Declare Function sndPlaySound Lib "winmm.dll" Alias "sndPlaySoundA" _
    (ByVal lpszSoundName As String, ByVal uFlags As Long) As Long
If GetLED (0) Then
sndPlaySound "C:\WINDOWS\MEDIA\tada.wav"
End If
If GetLed (19) Then
End If
or download the .M1s:
« Last Edit: June 06, 2006, 08:21:04 PM by zealouse »
