Hello Guest it is November 22, 2026, 02:09:59 PM
Author Topic: NFS question  (Read 21279 times)
Vmax
NFS question
« on: December 11, 2005, 06:51:53 PM »
Brian when using the circular pocket, is the spiral suppose to be symetrical in nature? When I cut a pocket the spiral comes out very wobbly in nature, the overlap is from 10% to 90% at times until it gets out to the finish cut and then it is a perfect circle. Terry Parker
Art
Re: NFS question
« Reply #1 on: December 11, 2005, 07:16:15 PM »
Hi Terry:
 I belive this is the math of the tool making sure it is at a % of tool diamter over the previous path, This is done to give a better finish to the end circle..
Art
Re: NFS question
« Reply #2 on: December 12, 2005, 09:21:53 AM »
The arcs that are making the cut is not a true spiral... Atrue spiral would have to be a bunch of VERY small moves:) As for the % tool Dia ... it is going to change a bit from the start to the end due to the fact that you can't start the cut without taking 100% of the tool.
Hope that helps just a little.
Thank you
Brian
www.newfangledsolutions.com
www.machsupport.com
