Hello Guest it is October 31, 2026, 12:34:56 PM
Author Topic: Reconfigure USB Jogging Dongle  (Read 14919 times)
« on: August 13, 2008, 11:48:36 PM »
Been away from the forum for a while . To busy building.
My question is : I have a controller with a "USB jogging dongle" supplied. I want to use one of the buttons on the dongle to produce a rapid jog. Can anyone give me an idea of where I should look in Mach3 or elsewhere in order to reconfigure the buttons for this use.
Bruce
Re: Reconfigure USB Jogging Dongle
« Reply #1 on: August 14, 2008, 05:50:08 AM »
If windows recognizes the dongel as a HID device you could easily set that up in Keygrabber.
« Reply #2 on: August 14, 2008, 09:39:05 PM »
I have had a brief look at keygrabber in the Mach3 folder. Is it intuitive to use, or is there a tutorial / guide?
Bruce
Offline Greolt
  •  956 956
« Reply #3 on: August 14, 2008, 11:54:41 PM »
Bruce I have not used Keygrabber but there is info on using it in this PDF
http://www.machsupport.com/docs/Mach2_6.11_Custom.pdf
What is this dongle thing you have?
Greg
« Reply #4 on: August 15, 2008, 12:25:57 AM »
Thanks Greg,
I should have known this.
The dongle came with the controller from Low Cost CNC Retrofit.  It is a push button system for X Y Z A etc. I plan to reconfig  one of the spare buttons for "Rapid Jog"
Incidentally I  have ordered my 2.2kw Spindle etc. from Saka. Should arrive shortly ( the O games are slowing things). Have you got yours up and running?
I also have taken delivery of the small 3 axis machine from Saka for our School . I have just about ironed out all the bugs and its working nicely.
Cheers.
Bruce
« Last Edit: August 15, 2008, 12:30:59 AM by MachBruce »
