Hello Guest it is November 14, 2026, 06:04:02 PM
Author Topic: Scripting Help Tool Zero  (Read 28264 times)
Re: Scripting Help Tool Zero
« Reply #10 on: August 16, 2008, 08:33:22 PM »
Phil, I think i understand what you want. I have sent you a Personal message.
Offline Greolt
  •  956 956
« Reply #11 on: August 17, 2008, 01:42:29 AM »
Phill
I have now tested the script I suggested.
It works perfect on LPT and SmoothStepper.
So the line that I was not sure about syntax, is good.
PlateThickness = 3.0 + GetUserDRO(1151) 'Set touch plate thickness here and it will add the material thickness from the onscreen DRO
Greg
« Reply #12 on: August 17, 2008, 04:43:59 AM »
Hi Greolt,
I have just tested the script it does exactly what i want.  ;D
It seems explaining what you want is harder than the actual coding.  ::)
Thanks also to Brett "Chaoticone" for your kind offer via PM and help thus far but Greolt just beat you to it.
This came about as i am engineering rather than routing and i cannot always get my touch plate in a position to get a Touch
So i touch off on another face and either add or subtract to get me back to where my datum is.
I did not want the zero tool thickness coming into the equation "Outside Of The Script" as a mistake can have disastrous consequences IE i wanted that thickness left hard coded where it would always be correct.
I think i may change the title to reflect what i consider a usefull addition to the Auto Tool Zero Script.
Phil_H
« Reply #13 on: August 17, 2008, 06:25:57 AM »
Glad Greg got you sorted Phil. Thats what it is all about. Good job Greg.
