Hello Guest it is November 04, 2026, 08:55:29 AM
Author Topic: Ok, first stupid question ;o) ....Hood?  (Read 159216 times)
Re: Ok, first stupid question ;o) ....Hood?
« Reply #10 on: August 12, 2008, 06:48:44 PM »
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #11 on: August 13, 2008, 12:48:17 AM »
Hi!
Device configuration is stored in PoKeys.
PoKeys software do configuration only and nothing else.
If you want to manage outputs, you should use PoKeys console.exe or C net example.
Look in user manual from page 9.
regards
Boris Zalokar
PoLabs
« Reply #12 on: August 13, 2008, 04:00:02 AM »
Hi Boris,
I was trying to use the console last night but when I click on the icon to start the program, the screen pops up for only a second and then goes away like it's having a problem starting up.
I think I'll try re-downloading the program again and re-installing.
Hood, have you tried using the console yet?
Thanks again, Boris-  :)
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #13 on: August 13, 2008, 04:25:19 AM »
If you want to use console and remain it opened, you should first open console and navigate to PoKeys console.exe
regards
Boris
« Reply #14 on: August 13, 2008, 05:01:26 AM »
Dave, just tried what Boris has said  and what you need to do is open command prompt from XP start>All Programs>accessories you can then navigate to the program files\pokeys directory and run pokeys console.exe
 I dont have my PoKeys here at the workshop so I can only use in Demo mode but it seems to work.
 If you are not familiar with DOS (I am not so really struggle ;) ) what you need to type at the command prompt is cd c:\program files\pokeys  (note, make sure there is a space between cd and the rest)
that should get you to the right directory then in the next command just type pokeys console.exe
« Reply #15 on: August 13, 2008, 11:06:02 AM »
Thanks for the help fellas but let me explain a little clearer with pictures, lol!
I can get to the application window with all the buttons but I can't get to the DOS screen (Pokeys Console) in the screen shot below when I click on the program "PoKeys Console" as shown in the small screen shot of it in the Programs menu.
« Reply #16 on: August 13, 2008, 11:43:29 AM »
Ok, tried something else.
Hood, you told me to type "pokeys console.exe" but I notice in the program folders directory that it's called "pokeysconsole.exe"  (no space between words), so I called that up and the Console comes up correctly.
So why doesn't the shortcut work that was provided?
« Reply #17 on: August 13, 2008, 12:13:22 PM »
Sorry, yes typed it wrong :(
Shortcut probably doesnt work as XP is not a DOS based system but as I know nothing much about the subject I am probably totally wrong :D
« Reply #18 on: August 13, 2008, 12:16:35 PM »
lol. no worries, I don't use DOS much either and when I do, I usually have to break out the book for that-  ;D
Thanks again-
