Hello Guest it is October 16, 2026, 02:14:24 AM
Author Topic: Installed Mach3 after hard drive failure  (Read 16575 times)
Offline CJEls
  •  69 69
« on: August 10, 2008, 03:47:56 AM »
Hi all
I installed mach on a new hard drive after my origanal drive failed but now I can not get the turret going.I did copy the XLM file to give me the same setup and i did check that all the settings were correct. I use the same Xp  software as before. It seems thet it is not reading the M6 macro. If you call for atool change the dro does change but the turret is not moving.Any suggestions
CJ
Re: Installed Mach3 after hard drive failure
« Reply #1 on: August 10, 2008, 06:18:04 AM »
Did you remember to copy over the M6Start.m1s into the correct profile macro folder?
Offline CJEls
  •  69 69
« Reply #2 on: August 10, 2008, 06:44:39 AM »
Hallo Hood
Yes I did.
Cj
« Reply #3 on: August 10, 2008, 07:31:52 AM »
Well if its definitely in the correct profile in the macro folder then it should work. Any more info about the toolchanger? How does it connect ie is it Modbus and PLC or just I/O from the PP or Modbus through ModIO or Arturos stuff?
 Is this a mill or lathe?
« Reply #4 on: August 10, 2008, 09:11:14 AM »
In General config, top left,  what do you have set as tool change option?
Offline CJEls
  •  69 69
« Reply #5 on: August 10, 2008, 03:03:07 PM »
Hallo Hood
It is a lathe.I do not know if XP service pack 3 has a problem with the set up. I am re formating the drive and will only load Xp with service pack 2,this is how the previose drive were set up.I hope this will help.
« Reply #6 on: August 10, 2008, 03:09:14 PM »
Its just SP2 I use but never heard anyone saying SP3 didnt work but heres hoping it cures your probs.
