Hello Guest it is November 01, 2026, 12:42:18 PM
Author Topic: Lazycam size problem - svg  (Read 10043 times)
« on: August 07, 2008, 05:29:45 PM »
Hello guys,
I'm new to CNC mill and I'm just looking at mach3/lazycam. I'm using Illustrator CS3 to create my drawings and saving them as SVG as the support for DXF is not really good.
The problem I have is that the scaling of the drawing once imported into Lazycam is not the same, I have a 7" circle in Illustrator but once in LC it shows up as 504 units. I looked at the source of my svg and it is saved as 504... but pixels.
I looked at the SVG specification (http://www.w3.org/TR/SVG11/coords.html) and PX is a supported measurement unit. Should it be supported under LC? if not anyone know of a converter?
I'm attaching an example. The outside circle is supposed to be 7"
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Lazycam size problem - svg
« Reply #1 on: August 07, 2008, 06:35:35 PM »
Hi, Boboxx
Don't now if I can Load it, You should be able to scale it in LCam though or do it in your Cad.
Chip
« Reply #2 on: August 07, 2008, 07:22:29 PM »
Hey Chip,
I just tried it but you lose some precision....
I set the X and Y to 7" but if I go back in it's set to 7.006
