Hello Guest it is November 17, 2026, 01:15:01 AM
Author Topic: Very basic question about tool diameter compensation  (Read 100142 times)
g41&g42 cutter componsation error
« Reply #40 on: February 04, 2013, 02:36:18 AM »
hi ,
i am using mach3mill latest version R3.043.067.
1)when tool compensation g41 or g42 is used the inner circle dosent seem to close when i stimulate & also run it online using machine.
i have attached the g code and screen short of the eg files.
g code program is made for the corresponding size.
[sq size 50x50 with fillet 5mm and inner 20mm dia circle].
need help .please clarify
regards
adhityanpt
india
Re: Very basic question about tool diameter compensation
« Reply #41 on: February 04, 2013, 03:15:58 AM »
Can you attach your xml file.
Just tried the iner one and works here.
« Reply #42 on: February 04, 2013, 09:27:42 AM »
I see the same problem testing in V.067.
