Hello Guest it is October 31, 2026, 12:35:30 PM
Author Topic: having flat spots in circles need help adjusting  (Read 30054 times)
Re: having flat spots in circles need help adjusting
« Reply #10 on: August 05, 2008, 06:50:53 PM »
Arrow to arrow is the x axis
« Reply #11 on: August 05, 2008, 11:07:02 PM »
I would try to eliminate as much backlash as possible by mechanical means. Sounds like you have about .022 to me and that is quite a bit.  :(  Even with backlash comp. set up, a tool can pull and push the work. You could go into Config, backlash and set the values for each axis there. I would try starting with a backlash speed of 200% and then go to Config., General config, center top and set shuttle accel to .05 seconds.
Let us know how this does,
« Reply #12 on: August 24, 2008, 09:23:15 PM »
replaced the leadscrew nut for that axis and now i have backlash programmed for .006 and that solved the problem
« Reply #13 on: August 24, 2008, 09:30:36 PM »
Good deal. Glad you got sorted.  :)
