Hello Guest it is November 27, 2026, 10:29:18 PM
Author Topic: Probing and plate alignment  (Read 81218 times)
Re: Probing and plate alignment
« Reply #20 on: November 06, 2011, 03:28:00 PM »
You CAN set the point of rotation with a G68 call. I will Check the wizard to see what it is doing.
With the Wizard you don't tell Mach anything it records the point you are currently located at.  then when you move to the second point it does the same thing.
After the rotation is set then you would move to a known point and set that as the reference point.
NOW NOTE: The 2 reference marks on the part must be on the same plane as each other  OR you would have to add in that offset angle.  But normally lineup marks are created on the same plane to make things easy.
« Reply #21 on: November 06, 2011, 03:34:15 PM »
OK I just checked the Code for the SetRotation Wizard. It does NOT set the poijnt of rotation ONLY the rotion angle.
So you would have to go back and set a referrence point.
Now it is possible to modify the wizard to include the Reference point(first set point) as the point of rotation. AND 2 more Dros to input the correct values. That would allow it to set the reference point in MACH and rotate on that point.
« Reply #22 on: November 07, 2011, 11:01:25 AM »
Many thanks...all useful for when my webcam arrives!
« Reply #23 on: August 10, 2025, 08:10:22 AM »
greetings to everyone, is there any macro for this alignment of measurements in 4 points, here in the picture shown 3, but it needs 4 points and automatic rotation and automatic position X0 Y0
« Last Edit: August 10, 2025, 08:11:59 AM by aluplastvz »
