Hello
Guest
it is
October 25, 2026, 05:57:58 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Abnornal Refall Light
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Abnornal Refall Light (Read 29261 times)
Chip
2,055
Gainesville Florida USA
Re: Abnornal Refall Light
Reply #10 on:
July 27, 2008, 06:18:05 PM »
Hi, Inivator
It could be a number of things, Acceleration set a little to high, If there are any G00 moves Velocity to high, Power Supply volts or amp's not sufficient, Current on your stepper board set low.
Tell us about your setup.
Thanks, Chip
Logged
inivator
102
Reply #11 on:
July 27, 2008, 06:24:09 PM »
NOTHING IN THE SET-UP HAS CHANGED. THE POWER SUPPLY AND BOARDS ARE THE SAME SINCE DAY ONE. THE ONLY CHANGE THAT I HAVE MADE IS TUNING OF THE MOTORS. ALL ARE TUNED TO ABOUT THE SAME SPEED AND ACCELERATION. I HAVE SET THE LOOK-UP TO 200, IT WAS 2. I HAVE NOT RUN THE MACHINE SINCE THE LOOK-AHEAD WAS CHANGED. I HOPE THIS WILL HELP THE PROBLEM..
INIVATOR
Last Edit: July 27, 2008, 06:25:53 PM by inivator
Logged
Chip
2,055
Reply #12 on:
July 27, 2008, 06:36:47 PM »
Hi, Inivator
Have you done these short segment type files in the past.?
Is Mach setup in CV or Exact Stop mode in Config, General Config.?
A Look Ahead of 200 is big and probably won't help if your in Exact Stop mode.
Chip
Logged
inivator
102
Reply #13 on:
July 27, 2008, 06:42:48 PM »
IT IS IN THE CV MODE.....................
INIVATOR
Logged
Carnoustie, Scotland
Reply #14 on:
July 27, 2008, 06:47:01 PM »
Turn your acell down a bit and try again.
Logged
inivator
102
Reply #15 on:
July 27, 2008, 06:51:36 PM »
I'LL TRY THAT...THANKS. I WON'T BE DOING ANYTHING ELSE TODAY, THE BOSS-LADY SAYS IT IS HONEY-DO TIME.
AGAIN THANKS
INIVATOR
Logged
Print
Pages:
1
2
Go Up
« previous
next »
