Hello Guest it is October 21, 2026, 07:31:50 AM
Author Topic: Is jog one speed only?  (Read 18438 times)
Offline Kristin D
  •  203 203
  • Take that you LazyCam, next stop the glue factory!
« on: July 21, 2008, 07:12:20 AM »
Just wondering if there is a way to change the jog speed without changing the motor tuning? Is there a hot key or something to run jog at say 50% 0r 25% speed?
Kristin
Just making automatic swarf for the first time today!
Re: Is jog one speed only?
« Reply #1 on: July 21, 2008, 07:27:25 AM »
Sure, hit your TAB key, then set it at whatever you like.
SHIFT and ARROW key overrides and goes to full speed set in MOtor Tuning.
RC
« Reply #2 on: July 21, 2008, 07:30:13 AM »
Also you have a Rapid Rate Override now in the mill, you can have your Feed Rate and Rapid rate overrides tied together or seperate. If you have it seperate then you can adjust the slider for the rapid and that will be your speed on a rapid.
Offline Kristin D
  •  203 203
« Reply #3 on: July 21, 2008, 07:36:16 AM »
Ha I guess I should have looked at the other screens to find that, just overexcited making auto swarf.
Kristin
PS- Hood don't you ever sleep? or did you just get up? Thought I was a night owl.
« Reply #4 on: July 21, 2008, 07:37:55 AM »
been up for 7 1/2 hrs now, its 13:38 here :)
Offline Kristin D
  •  203 203
« Reply #5 on: July 21, 2008, 07:59:51 AM »
Well I've been up for over 20 hrs, suppose it's time for some sleep  :D
« Reply #6 on: July 21, 2008, 08:09:14 AM »
yep, better get some rest, not good for you staying awake too long, you could end up like Brett :D
« Reply #7 on: July 21, 2008, 08:15:32 AM »
 :D
