Hello
Guest
it is
October 21, 2026, 07:32:12 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Is jog one speed only?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Is jog one speed only? (Read 18439 times)
Kristin D
203
Take that you LazyCam, next stop the glue factory!
on:
July 21, 2008, 07:12:20 AM »
Just wondering if there is a way to change the jog speed without changing the motor tuning? Is there a hot key or something to run jog at say 50% 0r 25% speed?
Kristin
Just making automatic swarf for the first time today!
Logged
Overloaded
4,923
Re: Is jog one speed only?
Reply #1 on:
July 21, 2008, 07:27:25 AM »
Sure, hit your TAB key, then set it at whatever you like.
SHIFT and ARROW key overrides and goes to full speed set in MOtor Tuning.
RC
Logged
Carnoustie, Scotland
Reply #2 on:
July 21, 2008, 07:30:13 AM »
Also you have a Rapid Rate Override now in the mill, you can have your Feed Rate and Rapid rate overrides tied together or seperate. If you have it seperate then you can adjust the slider for the rapid and that will be your speed on a rapid.
Logged
Kristin D
203
Reply #3 on:
July 21, 2008, 07:36:16 AM »
Ha I guess I should have looked at the other screens to find that, just overexcited making auto swarf.
Kristin
PS- Hood don't you ever sleep? or did you just get up? Thought I was a night owl.
Logged
Reply #4 on:
July 21, 2008, 07:37:55 AM »
been up for 7 1/2 hrs now, its 13:38 here
Logged
Kristin D
203
Reply #5 on:
July 21, 2008, 07:59:51 AM »
Quote from: Hood on July 21, 2008, 07:37:55 AM
Well I've been up for over 20 hrs, suppose it's time for some sleep
Logged
Reply #6 on:
July 21, 2008, 08:09:14 AM »
yep, better get some rest, not good for you staying awake too long, you could end up like Brett
Logged
Overloaded
4,923
Reply #7 on:
July 21, 2008, 08:15:32 AM »
Logged
Print
Pages:
1
Go Up
« previous
next »
