Hello Guest it is October 14, 2026, 09:46:12 AM
Author Topic: Mach3 no motors running  (Read 25224 times)
« on: July 09, 2008, 01:18:08 PM »
My Router table is homemade,Solsylva plans. It runs fine with Mach2 but not with Mach3....!!! Have no home or limit switches and no Estop. My PC is a dual core 3.40 Ghz, 1Gb Ram running on Windows XP. What could be the problem? Any ideas are welcome and appreciated. Thanks.
Re: Mach3 no motors running
« Reply #1 on: July 09, 2008, 01:39:22 PM »
have you got the motors enabled and set to the correct port and pins?
Do the DROs move when you jog an axis?
« Reply #2 on: July 09, 2008, 01:58:35 PM »
The DRO's move. port is No. 1....pins are 3,5,7 for X,Y,Z and 2,4,6 for directions...I am using the defaults pins as in the manual. Remenber it does work with Mach2...thanks for the imput.
« Reply #3 on: July 09, 2008, 02:32:39 PM »
So I presume its the same pins you have when using Mach2?
 Can you attach your xml for both Mach2 and Mach3. You will have to copy each of them to your desktop then rename them, suggest you call the AngelT2.xml and AngelT3.xml.
« Reply #4 on: July 10, 2008, 11:22:40 AM »
Finally "had" Mach3 running...the problem was the step pins and step ports were backward...ran for about 2 hours, went to lunch and when came back....you guess...Mach3 is not working, DRO's are not moving...double check the Motor outputs, they have not changed...going back to faithfull Mach2....!!!!
P.D. Hood, working on the XML files and send them to uou...thanks for you support.
« Reply #5 on: July 10, 2008, 01:21:58 PM »
Included are my two  XML files
« Reply #6 on: July 10, 2008, 04:03:01 PM »
Will have a look through them and see what I can find.
« Reply #7 on: July 10, 2008, 04:36:09 PM »
Had a quick look and the only thing so far that I see is you have the motor pins (step and direction)  set to Active Low in Mach2 but in Mach3 you have them Active High.
 One other thing you may want to try is setting the Step pulse to 5 on the motor tuning page.
« Reply #8 on: July 11, 2008, 02:41:15 PM »
Finally have Mach3 working...thanks to everyone involved in the solution...
« Reply #9 on: July 11, 2008, 03:04:15 PM »
what was the problem?
