Hello Guest it is November 26, 2026, 10:53:58 PM
Author Topic: new user : keeping old (2000) servo drive with mach 3  (Read 31012 times)
Re: new user : keeping old (2000) servo drive with mach 3
« Reply #10 on: July 08, 2008, 06:20:32 PM »
no it's not difficult , time consuming maybe !.
i am not familiar with the machine you have but we should be able to advise and walk you through
email me off list if you wish
where are you based ?
Thanks a lot i will surely email you if i go that route.
Is the encoder or decoder need to be special ??
I'm in canada quebec more precisely.
Not sure what you mean but if its can it be done then yes it can, will it work as good as before then yes it should and probably better. I have a large lathe from 1981 that I have retrofitted and its used daily and no problems.
You understood me correctly. Thanks
I will look into rutex.
« Reply #11 on: July 09, 2008, 08:44:52 AM »
I will post pics of the machine tomorrow it will clear thing up.
