Hello Guest it is November 22, 2026, 09:11:08 PM
Author Topic: profiles quest  (Read 22088 times)
davestea
profiles quest
« on: May 24, 2006, 09:26:27 PM »
can someone tell me where I can find different brand mill profiles?
I'm specifically looking for the Taig mill -
thanks -
Re: profiles quest
« Reply #1 on: May 25, 2006, 10:00:08 AM »
Take a look on the FTP server (Machsupport -> support -> FTP )
Hope that helps
Brian
www.newfangledsolutions.com
www.machsupport.com
davestea
Re: profiles quest
« Reply #2 on: May 27, 2006, 10:37:55 AM »
ahhh...  took a little digging but found the profile for the Taig Mill --
big Big but... here guys -
BRIAN ???  -- { I guess three question marks does this - sorry - not mad }
downloaded it and dropped it with the other xml profiles and good, it shows up in the
profile select list --
but when I select and open it I get a blank screen - completely blank -
I loaded it on two different systems and versions -
  84.001 on a new HP system
  90.037 on this Sony system
both version do the same thing - dead blank M3 screen.
Help?
tnx
« Last Edit: May 27, 2006, 10:39:27 AM by davestea »
Re: profiles quest
« Reply #3 on: May 27, 2006, 07:22:08 PM »
If the screen will not load go to View-> Load Screens->1024.set and you should get the standard screen set..
Hope thsat helps
Brian
www.machsupport.com
davestea
Re: profiles quest
« Reply #4 on: May 27, 2006, 07:47:34 PM »
ya it did --
I actually tried that after I'd written -
oddly I have to do that manually if I reboot -
closing and restarting work ok -  but at least I can make it work -
davestea
Re: profiles quest
« Reply #5 on: November 18, 2006, 10:37:44 AM »
bump
Re: profiles quest
« Reply #6 on: November 19, 2006, 09:28:44 AM »
The XML should be saved when you close Mach3 and that will save where the screen set you are using is... So it will not load the screen set when you start the program?
www.machsupport.com
Offline PaulWC
  •  125 125
Re: profiles quest
« Reply #7 on: November 20, 2006, 12:57:05 AM »
The "Mach3Taig2000.xml" on the FTP server is set for a non-existant screen set "MPS1024D.set".  That may be the proprietary OEM screen set provided by MicroProto when Mach3 is purchased with one of their systems.
As mentioned before, loading "1024.set" will provide a viewable screen... as well as the other screen sets available at the MachSupport download area.
Paul, Central OR
