Hello Guest it is September 05, 2026, 01:32:04 PM
Author Topic: where is the motor reversal box  (Read 20484 times)
« on: December 06, 2005, 12:57:20 PM »
Where is the motor reversal box located?  Mach2 has it in configuration…….
I love mach2 but wanted to stay up to date and use mach3. do i have to switch the wires on my drives?
Cheers,
Tim svec
Re: where is the motor reversal box
« Reply #1 on: December 06, 2005, 01:06:11 PM »
They are in the config--> homing/limits, there is a column that says reversed, you can add a checkmark to the ones you want reversed.
Hope this helps
Fernando
« Reply #2 on: December 06, 2005, 07:28:31 PM »
The other way to change this is under the ports and pins Active Low setting for the Dir pin on that axis...
Hope that helps
Brian
www.newfangledsolutions.com
www.machsupport.com
