Hello Guest it is October 06, 2026, 04:15:54 AM
Author Topic: Arcs I ... K .... and all the others  (Read 10404 times)
Offline Tef9
  •  89 89
« on: June 23, 2008, 08:15:49 AM »
Hello,
I am looking to Gcode a basic arc, however I have no idea where to start, I have written taper, and (thanks to Graham) doubble tapers so I suppose an arc is the next logical progression.  I know they use the I and K values however this is the limit of my knowledge.
If anyone has a straighfoward example they could share or code somthing up quickly that would be great.
I am useing a small sherline cnc lathe.
Cheers,
Andy
Re: Arcs I ... K .... and all the others
« Reply #1 on: June 23, 2008, 08:49:40 AM »
Hello Andy,
http://www.machsupport.com/docs/Mach3Turn_1.84.pdf
Check out chapter 10.7.3
It should answer most of your questions.
RC
Offline Tef9
  •  89 89
« Reply #2 on: June 23, 2008, 09:05:28 AM »
Thanks for this, and gives me somthnig to read, however I do learn better with code examples if any one has a simple one to offer.
Andy
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #3 on: June 23, 2008, 04:56:32 PM »
Ok, here is a bit of code :-
For a lathe to put a 5mm rad on the end of a bar in diameter mode.
G00 X0 Z0 (move to start point)
G03 X10. Z-5. R5. (form rad)
G00 X50. Z50.(rapid away)
Graham.
