Hello
Guest
it is
November 21, 2026, 10:27:29 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
MPG`S
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: MPG`S (Read 22140 times)
marty
4
MPG`S
on:
October 26, 2005, 04:35:56 PM »
HI ALL
MPG
i will be geting one but i need some info
i will be useing mach3 i have added port
i thank incremntal 100 p/r not sure on the out put (totem pole) or (line driver) or (voltage)
and power supply (5~14vdc) or (5vdc) is thare one that is like
thank for the help marty
Art
Re: MPG`S
Reply #1 on:
October 27, 2005, 09:55:43 AM »
Hi Marty:
I use a 100CPR myself. I use a cuttoff USB cable for power. Works very well..
Art
Horst Walter
Re: MPG`S
Reply #2 on:
January 18, 2006, 03:03:59 AM »
Hi Art,
is there any key to hold the MPG-MODE constantly on the top of the screen?
Usually you get it via TAB – Key, but if you make any change between the pages the MPG-MODE disappears!
Regard
Horst
Print
Pages:
1
Go Up
« previous
next »
