Hello
Guest
it is
November 23, 2026, 04:24:39 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Path not correct
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Path not correct (Read 28822 times)
Chaoticone
5,624
Precision Chaos
Re: Path not correct
Reply #10 on:
June 11, 2008, 04:03:04 PM »
Also, You can't change directions with the jog buttons as fast as Mach can while running code. Not possible. Detune your accel. and let me know how it does.
Logged
If you could see the things I have in my head, you would be laughing too.
da21
87
Reply #11 on:
June 11, 2008, 04:23:28 PM »
is there any other software running in the background ? , antivirus , backup , etc , this will also affect performance issues , if it happens to be running tasks at the times you have problems , this includes Updates or network activity
Logged
Freeze_Tec
7
Reply #12 on:
June 12, 2008, 05:56:32 AM »
Hi Maurizio,
Do you also get a false path on the computer screen when things go wrong?
If yes, you are facing the same problems I had.
In my case the problems were solved after I set the "Look ahead" (Config screen) to 1
Good luck
Jan
Logged
Print
Pages:
1
2
Go Up
« previous
next »
