Hello Guest it is November 12, 2026, 06:31:20 PM
Author Topic: Spindle encoder disk diameter?  (Read 30941 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Spindle encoder disk diameter?
« Reply #10 on: June 10, 2008, 09:53:45 PM »
Hi, panaceabeachbum
If your encoder has a Index pulse output you can use a IC 555 timer, It detects the Pulse then delays the reset to give Mach time to see the pulse.
I've got the diag. around hear somewhere, I posted it awhile back Hear, One way or the other will find it.
Edit: Hears the basic Diag, needed.
Chip
« Last Edit: June 10, 2008, 10:08:06 PM by Chip »
