Hello Guest it is October 20, 2026, 03:59:45 PM
Author Topic: Buttons that write numbers in DROs.  (Read 13081 times)
« on: May 27, 2008, 02:22:02 AM »
Is there any way to create some buttons that will insert numbers to DROs?
Like a numeric pad i mean.
Re: Buttons that write numbers in DROs.
« Reply #1 on: May 27, 2008, 05:41:55 AM »
You can enable the onscreen number pad, when you click on a DRO the keypad will pop up and ytou can enter the numbers.  Is that what you are wanting? Its on the Operator Menu and choose  Auto Calculator.
« Reply #2 on: May 27, 2008, 06:30:13 AM »
Its not really what i want.
I want it to be appeared on a screen and have bigger buttons.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #3 on: May 28, 2008, 07:32:34 AM »
One way to do this is to have a DRO select button that indicates which dro is active.
Then you can read which is the active dro, read the dro's contents, update it, and write it back.
Note.  NOT all dro's are writeable.
Graham.
