Hello Guest it is November 27, 2026, 02:33:14 AM
Author Topic: Problems,Problems, Problems, Wiring  (Read 28408 times)
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
Re: Problems,Problems, Problems, Wiring
« Reply #10 on: May 29, 2008, 12:03:42 PM »
Pardon me asking = what is "Electro Anxiety" ???
« Reply #11 on: May 29, 2008, 01:14:53 PM »
That's what I call my complete and absolute lack of knowledge, and interest, in anything electrical or having to do with electronics of any kind. I have always found it too mysterious and complicated to deal with. I barely passed it in college, I tghink I got a high F grade.
Offline jimpinder
  •  1,232 1,232
« Reply #12 on: May 30, 2008, 10:48:33 AM »
I thought it was something like that - but, unfortunately,  when dealing with CNC, unless gas or hydraulicly operated, a bit of knowledge and interest would be a great help.
Come on !!  You are not in school now - there is a practical application to all this that you can benefit from.
« Reply #13 on: May 29, 2014, 01:25:18 AM »
Hi hood i need some help from your side i have same problem my motor turning on one direction im using smoothsteper usb and c10 have same problem if i change in mach3 pin &port  it was tuirning other side driver motor working what i can do now please help me.
mukesh
« Reply #14 on: May 30, 2014, 02:21:52 AM »
not sure what you are meaning with
"if i change in mach3 pin &port"
If I understand then if you change the port and in numbers it will change which outputs are being used, so obviously you need the correct Port and Pin assigned for it to work as intended.
