Hello Guest it is November 23, 2026, 03:05:57 AM
Author Topic: OD Arc Wizard  (Read 14184 times)
OD Arc Wizard
« on: May 25, 2008, 07:23:38 PM »
Hi
Just running mach 3 on the lathe
Up graded to the latest V as I was having problems with taper threads.
The threads are now working fine, but when I use a wizard that has
any arcs(OD Arc Wizard: ie g03 or go2) the program is cuting a full
circles.
I was trying to put a radius on the end of a 0.525" shaft and
the program keeps trying to cut a full circle.
Several inserts down :(
any help!
take care
eddie
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: OD Arc Wizard
« Reply #1 on: May 25, 2008, 09:25:54 PM »
Hi, Eddie
Your preamble at the top of your G-code needs a G91.1 or G90.1 to set the I J's to Inc or Abs Mode depending haw the code is written.
Use the MDI line to change it, It should fix it.
In your G-code put the G9#.# on a separate line from other G9## code as below Mach doesn't like it.
G90
G91.1
Hope this Helps, Chip
Offline Chip
  •  2,055 2,055
Re: OD Arc Wizard
« Reply #2 on: May 25, 2008, 09:54:52 PM »
Hi, Eddie, Rich
That can cause problems also.
Thanks, Chip
Offline Chip
  •  2,055 2,055
Re: OD Arc Wizard
« Reply #3 on: May 25, 2008, 10:23:40 PM »
Hi, Rich
Hear you Loud and Clear on that, For Sure.
Been using a startup string and the Use on "All Resets Option", To level the playing field a little.
Sorta forces Me to add Preamble code in My G-code, May not the thing to do, G90 G20 G17 G40 G49 G61 G69 G50 G80 G94 G91.1 G52x0y0z0  F100
Chip
« Last Edit: May 25, 2008, 11:07:52 PM by Chip »
