Hello
Guest
it is
November 22, 2026, 10:15:04 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Cant find any import commands in Mach3
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Cant find any import commands in Mach3 (Read 18256 times)
Jimmy H
on:
May 18, 2006, 06:54:53 PM »
I know in Mach2 it was very obvious and under the FILE menu.
Using version 1.9 of Mach3 and there is no import option under the FILE menu.
Jimmy
Logged
sshneider
401
Re: Cant find any import commands in Mach3
Reply #1 on:
May 18, 2006, 10:11:17 PM »
Yeah, 1.9 is kinda new for all of us in that respect. Version 1.84 has an import function under the file menu. In 1.9 you use Lazy Cam to do the import and generate the code.
HTH,
Sid
Logged
Jimmy H
Reply #2 on:
May 18, 2006, 10:31:43 PM »
Kinda thought that might have been the case. Even looked at lazy cam..but couldnt figure it out.
Im just in the process of calibrating my router.
I went ahead and went back to 1.84 to keep in the comfort zone.
Jimmy
Logged
Brian Barker
3,860
Reply #3 on:
May 19, 2006, 10:43:04 PM »
There will be video's on Lazy Cam but it is going to be after I do a few bug fixes.... Art and I are going to each do a video, This should help you get you the point where you can run Lcam.
Thank you and sorry for the trouble
Brian
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Jimmy H
Reply #4 on:
May 22, 2006, 08:50:21 AM »
no apology necessary...this software is great and still work in progress.
I really appreciate what all of you have done here.
Looking forward to the videos
Jimmy
Logged
Print
Pages:
1
Go Up
« previous
next »
