Hello Guest it is November 01, 2026, 12:41:30 PM
Author Topic: No tabs  (Read 30952 times)
Re: No tabs
« Reply #10 on: May 26, 2008, 07:14:24 AM »
Then, tabs in LC and the results in Mach3.
Re: No tabs
« Reply #11 on: May 26, 2008, 11:14:22 AM »
It may be something about a beta product or may be my lack of understanding... is this a lead in issue..  What is a lead in?
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: No tabs
« Reply #12 on: May 26, 2008, 02:44:07 PM »
Hi, CurtisU
What ver. of LCam are you using, 3.00.2 hear, Posts the code fine with or without LC Lic.
Look under Help about in LC to see.
Thanks, Chip
Re: No tabs
« Reply #13 on: May 27, 2008, 06:55:29 PM »
Figured it out....    I was getting the sawtooth tab action when my connection tolerance was to large, 0.125" in my case, depth per pass on that tool  was set for 0.125", might be a correlation there.
LC version 3.00.2 here too.
That comment in one of the videos about having a look at the connection tolerance if you get strange postings had always been on my mind, I thought I'd already explored that avenue, oh well.
Until next time,
Curtis
Offline Chip
  •  2,055 2,055
Re: No tabs
« Reply #14 on: May 27, 2008, 08:42:18 PM »
Hi, CurtisU
Glad you got it sorted out.
Thanks, Chip
Re: No tabs
« Reply #15 on: May 28, 2008, 02:07:34 AM »
Hi Curtisu
If I may asc, did you use offsets in your project?
Greetsings:
Willem
Re: No tabs
« Reply #16 on: May 29, 2008, 05:24:31 PM »
Hello Willem,
Neither this example or the project I was trying to get coded were offsets, they were intended to be coded direct from the .dxf.
Curtis
