Hello Guest it is November 23, 2026, 05:08:44 PM
Author Topic: Importing DXF file to Mach2 doesn't work properly  (Read 11196 times)
« on: May 04, 2008, 12:07:09 AM »
Hi guys,  I want to use this DXF file and convert it to G code, but I'm not having any successful results with it.  I have attached two files a DXF.file and paint.file.  I using Proteus 7.2 to make my layout design and tring to use Mach2 to generate a g code so that I can use my HobbyCNC controller.  I haven't had any problem with using Rhinoceros 4.0 with Mach2, just this DXF file doesn't work properly.  I don't know what I should do next, I would be so grateful if someone here could try this DXF.file out and see if the G code generates the same image as the other file attached.
Edit: I have attached also the text files that Proteus has made, just incase that helps somehow.
« Last Edit: May 04, 2008, 12:24:59 AM by vertigo »
