Hello Guest it is October 04, 2026, 06:29:43 PM
Author Topic: gcode  (Read 15992 times)
Offline moxy
  •  34 34
gcode
« on: May 03, 2008, 03:26:56 PM »
Hi all, I'm using Eagle pcb to design (guess what!) pcbs and would dearly like to know how to convert my hard work into a gcode file. Any help will be much appreciated.
Many thanks
Les
Re: gcode
« Reply #1 on: May 03, 2008, 03:51:51 PM »
Can you save the files as DXF, if so then maybe you can use LazyCAM to produce the code.
Re: gcode
« Reply #2 on: May 03, 2008, 07:06:18 PM »
Eagle has cam functionality. How functional it really is I do not know.
Offline moxy
  •  34 34
Re: gcode
« Reply #3 on: May 04, 2008, 03:22:34 AM »
Hi All, Thanks for the replies. I persevered with eagle and found that you can run a program called mill-outlines.ulp which does the job. It can then be saved as filename.plt. I still have to play about with it further to see what final results I get.
Many thanks
Les
Offline moxy
  •  34 34
Re: gcode
« Reply #4 on: May 07, 2008, 01:34:23 AM »
Hi Guys, further surfing on the net has found a free download which does the job perfectly. Search for PCB-GCODE and you will get to the site. it creates code for both sides of the board and a drill file.
many thanks
Les
Re: gcode
« Reply #5 on: May 07, 2008, 04:30:35 AM »
Thanks for posting Les, hopefully it will help others if they need such a programme.
Re: gcode
« Reply #6 on: May 08, 2008, 05:47:47 PM »
There is an add-on four Eagle that will output a DXF file of your PCB design, it was developed by enthusiasts and is freely available or at least was freely available, I think I downloaded the add-on from Eagles web site quite some time ago seemed to work just fine, although I didn't have a mill to actually make a PCB.
Darren.
