Hello Guest it is November 22, 2026, 03:19:33 PM
Author Topic: Drilling holes using Lazy cam  (Read 31817 times)
Re: Drilling holes using Lazy cam
« Reply #10 on: May 22, 2009, 11:06:06 AM »
while plasma cutting does not apply to this situation, i will draw a dot where i want a pierce hole that will be drilled later. the dot will have a m3 m5 in the gcode.
« Reply #11 on: May 22, 2009, 03:38:16 PM »
Now, can anyone help me?
Is there a way of making a dot using Corel Draw.  I have never been able to find out how, or if it is even possible.
JonnyElectronny
« Reply #12 on: May 26, 2009, 07:48:25 PM »
Probably not a lot of help, but I had the same problem using Corel Designer. I had to export as HPGL to get LC to make any sense of the file.
I now use Visio. The drawing tools are a bit of a learning curve, but now I can do any drawing that I used to do in Designer and saving as a DXF is read every time exactly as it should be by LC.
