Hello Guest it is October 07, 2026, 07:23:56 AM
Author Topic: Help!!!!!  (Read 37899 times)
Re: Help!!!!!
« Reply #20 on: April 02, 2008, 03:11:14 AM »
leave "output arcs as linear motions" UNCHECKED then the circular part of the hole will be smooth - it's just the spiral lead-in that'll end up as line segments - but with CV on Mach will interpolate a smooth curve anyway.  VM wants to make a spiral move with an R3 with a Q, if you take the Q out you'll just get an arc (not a spiral) which is almost certainly not what VM wants the toolpath to look like.
I can edit the post for the Q if needed.
When I cut a circle I wont it to be smooth without the little flats,
so witch one do I leave unchecked?
Offline TT350
  •  113 113
Re: Help!!!!!
« Reply #21 on: April 03, 2008, 08:39:24 AM »
I deleted the Q from the post with no luck, it cut the hole the same.
I left the liner motions unchecked and put check marks in the other 2
and it cut a nice hole.
Thanks to all that responded to help me resolve this.
Chris
