Hello Guest it is November 13, 2026, 09:34:56 AM
Author Topic: Home switches  (Read 39784 times)
Re: Home switches
« Reply #20 on: March 28, 2008, 09:09:21 PM »
Thanks BluePinnacle...I may have to try that yet ,but it would take a drawing for me to follow that program... :)
I have resoldered all the switches and put Double shrinktube over the Soldered pin terminals on the switches, that made the connection much tighter, less movement..  Put noise suppressiors on all the wires between the switches.. Radio Shack said they work and they were cheap!!
Took Mach3 off my computer and reinstalled , just thought there might be a problem with the download !!  The Limit switches are working OK now, still have some work to do on the Home switches..
Problem I have now is in the tunning the motors, they won't jog when tunning??  The axis will jog when not in motor tunning ?? Haven't figgered that one out yet !!  Thanks for the great support.
Jimpinder..Criticism is good if it works and ,I believe it did.. ;D
