Hello Guest it is November 13, 2026, 08:08:02 PM
Author Topic: m3 not always recognized  (Read 41394 times)
Re: m3 not always recognized
« Reply #10 on: November 15, 2008, 07:43:20 AM »
Katoh
 What version of Mach are you using? It might be worth trying the latest Dev version as a lot of work has been done in the VB part of Mach
Offline Katoh
  •  287 287
« Reply #11 on: November 15, 2008, 07:55:24 AM »
Hi hood
Im running Version 2.63.
Katoh
« Reply #12 on: November 15, 2008, 08:03:49 AM »
What I would do is create a folder on your desktop and then go to the Mach3 folder and copy the Mach3.exe and paste it into the folder you created. I would also copy your xml and any custom macros. screens etc you may have and also the .dat files that are in your profiles macro folder as they contain such things as tooltables etc (thats if you have these set up)
 Once you have copied all you need then download and install the latest Dev version of Mach and give it a go, if it doesnt help you then all you need to do is go to your saved exe and paste it back into the Mach3 foilder, same with xml etc if needed.
Offline Katoh
  •  287 287
« Reply #13 on: November 15, 2008, 08:21:14 AM »
Thanks Hood
As you might be aware I'm still in the process of setting the whole thing up so I haven't got anything customised as yet, The only things is the actual machine settings, which Ill write down on a piece of paper all the settings to make It go, and then Ill load the latest version of Mach, set the settings up by using the info Ive written down and see what happens, For now its just hitting 1.30am and I'm deciding either to go to bed or watch the Wallabies play the Lions in Twickinham(hope I spelt that right) So this will be on tomorrows to do list. Do you remove the old Mach before updating or leave it and run the up datated version?
Thanks Again
Katoh
Katoh
« Reply #14 on: November 15, 2008, 08:38:33 AM »
LOL well its the Ozzys and England but the better one to watch would be the Sprigboks and Scotland ;) I am watching the score online while at the workshop.
 The xml holds all of your pin settings etc so always best to have a backup of that anyway.
No need to delete the old version of Mach, the installing of any version of Mach3 will overwrite any files needed so dont worry there.
Offline Katoh
  •  287 287
« Reply #15 on: November 15, 2008, 09:17:31 AM »
Thanks again Hood
Ill do that! Starting whatching the Game its a good fast one. But I'm sorry to say We will run away with it in the second Half, I don't think the English can keep up the Pace.
Katoh
Katoh
« Reply #16 on: November 15, 2008, 09:19:23 AM »
Heres hoping your prediction is true
Offline Katoh
  •  287 287
« Reply #17 on: November 15, 2008, 10:16:06 AM »
Yep. Spot on, 14 to 28 our favour, I reckon scotland may have a good chance against the Sprinbocks, there a bit off there game lately, They dont seem to travel well, were the All blacks are a different story.
Katoh
« Reply #18 on: November 15, 2008, 10:35:45 AM »
Well true to form Scotland play well but lose ;D maybe one day things will go our way, wonder if I will be still alive.
Offline Katoh
  •  287 287
« Reply #19 on: November 15, 2008, 05:09:17 PM »
Hood, one can only hope! It ll be a great day when I see a nation not part of the top 5 hoist the William Webb Trophy over their heads in triumph. It Might be the Scott,s in Wales You never know.
Katoh
