Hello Guest it is October 20, 2026, 03:01:38 PM
Author Topic: Problem on opening Mach 3  (Read 11722 times)
« on: March 15, 2008, 07:56:47 AM »
I have installed Mach 3 and from the moment i open the programme all my motors turn a step every few seconds and I cannot for the life of me stop them.
When I run a G code it all works fine but a few seconds after the g code is finished the motors start turning again every few seconds.
Can anyone help please?
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Problem on opening Mach 3
« Reply #1 on: March 15, 2008, 11:19:50 AM »
Hi, Hunnam
If your DRO's aren't moving, Then it must be some other program in the background on your computer.
Did you Re-Boot your computer after installing Mach3 ?
Run the Driver Test, It's in C:\mach3\  folder.
Re-Install Mach3.
May need to referr to the Optimization Doc. hear  http://www.machsupport.com/optimisation%20XP.txt
Thanks, Chip
« Reply #2 on: March 15, 2008, 09:18:24 PM »
Hunnam:
Check your electrical cables.  I had "twitchy," motors for a long time.  Ran fine, but when not running code the motors would jerk.  In addition the wireless mouse I use would occasionally not pickup all the moves.  Never could figure it out.  One day I was rearranging things on my bench and noticed a big difference in the mouse response.  My supply cords are long I had coiled them to prevent dangling.  When I moved the coiled electrical supply cords away from the wires running to my motors the twitching stopped.
Bob @ BobsShop - If a problem seems like it could be caused by some sort of electrical function - it usually is.
