Hello Guest it is October 20, 2026, 03:09:49 PM
Author Topic: Mach3 on 64 bit Windows XP? "No Driver sensed installed. Run Driver Test"  (Read 44661 times)
Re: Mach3 on 64 bit Windows XP? "No Driver sensed installed. Run Driver Test"
« Reply #10 on: February 21, 2009, 04:13:14 PM »
Dear Hood,
     I have tried all. Enabled the 2-7 pins in ports and pins. Also changed them to active low (on and off). Did the driver test. Came back excellent. And several other things.
     If I uninstall and reinstall, I know I would have to begin again but it that the right thing to do at this point?
Dan326
« Reply #11 on: February 21, 2009, 05:16:13 PM »
What exactly is wrong?
If you install over the top of itself you will not lose settings but it is always wise to copy the xml file for the profile you are using and if you ever lose your settings you just paste it into the Mach folder and you are back in business.
