Hello Guest it is November 22, 2026, 02:56:16 PM
Author Topic: want some simple circuit to test mach3 with a small step motor?  (Read 16810 times)
I just buy one step motor: oriental motor PK244-02BA with 6 wire DC
0.8A 7.5ohm 2 phase and a ic MC3479P stepped motor driver,
would like to know is there some simple circuit I can build and test
the step motor from the pc?
this 2 items cost me $12 but I think is the good start to learn
something new.
thanks
Offline chad
  •  361 361
  • When the going gets weird, the weird turn pro.
Re: want some simple circuit to test mach3 with a small step motor?
« Reply #1 on: May 04, 2006, 11:54:35 PM »
HI, wheel if you have a solid electronics background then you have everything you need to get started. I just looked at the data sheet and you don't need much else.
http://www.onsemi.com/pub/Collateral/MC3479-D.PDF
motor
Driver IC
parallel port
power supply
1 resistor (for current set)
Mach3 and a bread board.
wire
If you don't have an electronics background then i would recommend purchasing a small pre built stepper driver board, hooking that to the parallel port and get acquainted with things that way. I always end up spending more time building things that i should have just bought ;)
Chad
« Reply #2 on: May 05, 2006, 09:51:49 PM »
any small pre-build board that mach3 can use and talk thru it? any link?
thanks
