Hello Guest it is November 10, 2026, 01:52:48 AM
Author Topic: changing write wizard, maybe  (Read 12313 times)
« on: February 27, 2008, 12:49:24 PM »
hi all, i would like to change the write wizard by german bravo slightly..
 i want to change the small circle thing to a apostraphe ' .
 i have changed the VB attached to all the buttons on the wizard, but i can't find where his post code is.
it should dump to the teach file, but i cant find it.any ideas ?
dan
Re: changing write wizard, maybe
« Reply #1 on: February 27, 2008, 02:29:21 PM »
i see where he has a bunch of macros wrote,starting at M601 but what makes it choose  601-604 ? i can see where the 700's come in for the font type.
i just seem to be missing the actual transition point where he hands it off to the macro's
scratches head
dan
« Reply #2 on: February 29, 2008, 05:37:25 PM »
Dan,
Macros 600,601..., was used with old version of Write wizard.
The last version uses macros 7XX.
German
« Reply #3 on: February 29, 2008, 08:11:40 PM »
thanks,
will look at it from that perspective.
dan
« Reply #4 on: March 02, 2008, 08:33:44 PM »
ok, here's a zip file with the grado symbol changed to a apostrophe ( my customers wanted a apostrophe as in "Teri's Stuff"
i just placed a comma in the spot for grado and added 10 to the y and j dim's to raise it up
all the coding and such is still GBravo's
i appreciate him pointing out the entry ... maybe one day i can write code this complex
dan
