Hello Guest it is November 01, 2026, 10:05:52 AM
Author Topic: Help with LazyCam  (Read 13511 times)
cosmynnec
Help with LazyCam
« on: May 03, 2006, 11:56:56 AM »
I have this part with 2 layers, the 1 layer the outside of the piece the 2nd layer the circle in the middle of the piece.
I have tried everyway I can to get LazyCam to cut the circle on the inside instead of the outside. But it continues to cut outside . If I enable a straight lead-in of 3mm the leadin extends beyond the edge of the circle
Cosmy
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Help with LazyCam
« Reply #1 on: May 03, 2006, 11:21:26 PM »
Hi, Cosmy
Have you tryed the 45 or cir. leadin or is this a cutter dia. problem your having.
Try the Atachment below.
Hope this help's, Chip
cosmynnec
« Reply #2 on: May 04, 2006, 06:51:47 AM »
Yes my problem is the cutter dia. if i don't check that option "Use G41/G42 .... " when i want to generate the g-code it's working but without compensation. I think that the program reverses the G41 and G42 codes.
« Reply #3 on: May 04, 2006, 11:27:24 AM »
I have been fixing bugs and that one is on the list...
Thank you
www.newfangledsolutions.com
www.machsupport.com
