Hello Guest it is November 10, 2026, 09:47:08 PM
Author Topic: Starting on the Hurco  (Read 40503 times)
« on: February 22, 2008, 08:05:26 PM »
I will be retrofitting this Hurco over the next few weeks. It has a 12 position tool changer that I will modifying to accept BT 30 tool holders and will be using a DL06 to control the tool changes. I have no manuals what so ever. If any of you do, that would be helpful. I will be using 750watt AC servos for the three axis. I hope to use the exisiting servo and power supply for the tool chain.
« Last Edit: February 22, 2008, 08:11:10 PM by Chaoticone »
Offline Monty
  •  116 116
Re: Starting on the Hurco
« Reply #1 on: February 22, 2008, 08:16:48 PM »
Hey Brett,
Looks like you've got your work cut out for you. What type of tool holder does the machine currently use?
At least the thing is Y2K compiant ::).
I remember having to put those stickers on all kinds of crap when I worked for Lockheed. As if a machine tool needs to know when or where it is.....half the time I don't even know :D.
Monty
« Reply #2 on: February 22, 2008, 08:30:56 PM »
Hey Monty,
    It uses CT 30 tool holders now. They are very much the same, just the BT30 are cheaper and have more options. The only thing I will have to do I think is have some custom pull studs made and make new arms for the changer. This won't be bad at all. One of the arms is missing a little off the end and was going to make one new one anyways. This one should be much more robust than my stepper machine and faster I hope. This machine has been sitting for years. It was bought as one of a pair and was going to be used for spare parts. Some of the controls were taken and all but 2 of the air selonoids. Those are expensive :( . I think I will be using SMC modular manifold and valves.
Offline Monty
  •  116 116
« Reply #3 on: February 22, 2008, 09:16:08 PM »
Bummer about the solenoids. I've had some luck buying them surplus. You might try surplus center.
http://www.surpluscenter.com/sort.asp?UID=2008022221110548&catname=air&keyword=AVOC
Still not inexpensive, but hopefully a little less than what you have been looking at. If not there is always fleabay.
Maybe I'll have my lathe running by the time you need those pull studs.  ;)
Monty
« Reply #4 on: February 22, 2008, 09:43:04 PM »
Hello Brett,
Any idea what year it was mfg. ?
What is the spindle HP ?
Nice looking rig.
RC
« Reply #5 on: February 22, 2008, 09:47:05 PM »
Hey Rc,
    I have no idea what year it was made. I hope to get it cleaned up this week and look for some tags. It has a 5HP spindle.
« Reply #6 on: March 04, 2008, 09:35:52 PM »
I have a couple of videos posted at youtube. One of the tool chain spinnig and another of the x axis jogging at 600 IPM  :).
http://www.youtube.com/watch?v=sp3XqLhHP2w
http://www.youtube.com/watch?v=XehPG0hLxN4
« Reply #7 on: March 04, 2008, 10:08:03 PM »
Cool Brett !
Better make sure there's plenty of lube on those ways....I think I saw them SMOKIN" !  :D
RC
« Reply #8 on: May 04, 2008, 09:39:33 PM »
this is the mill running the galil, right?
« Reply #9 on: May 04, 2008, 11:16:18 PM »
Nope, I'm using a smooth stepper.
