Hello Guest it is September 14, 2026, 07:23:44 PM
Author Topic: LazyTurn  (Read 3497565 times)
0 Members and 12 Guests are viewing this topic.
Offline N4NV
  •  398 398
Re: Hard disk crash
« Reply #980 on: April 04, 2009, 05:20:58 PM »
I had a hard disk crash and lost all of my Mach directory (I have better back up now).  When I try to run the exe file in the lazyturn zip, I get the message that the file LvKrn15u.dll is missing and I need to re-install.  Any suggestions?
Vince
Re: LazyTurn
« Reply #981 on: April 04, 2009, 05:52:13 PM »
To All,
You can get a lot out of the simulation when looking for something just need to enlarge  the view and start
the movie.
See attached as this is not apparent by just looking at the path lines.
MODIFIED:
DAHHHH..... ! hold on here, as what i say can't be right for that line. There is a problem in the paths that are displayed.
Didn't notice it until I looked at the clearance anad path lines on the rest of the picture.
Too focused......time for a BEER!
« Last Edit: April 04, 2009, 06:01:41 PM by RICH »
Re: LazyTurn
« Reply #982 on: April 04, 2009, 06:09:08 PM »
Vince,
 are you also running this ?
Offline N4NV
  •  398 398
Re: LazyTurn
« Reply #983 on: April 04, 2009, 06:14:57 PM »
I am running the lazycam 3.00.2, but I don't see lazycam 3.00.2 update.
Vince
Re: LazyTurn
« Reply #984 on: April 04, 2009, 06:19:09 PM »
Re: LazyTurn
« Reply #985 on: April 04, 2009, 06:23:52 PM »
Rich,
   Curious...what tool and CUT settings did you use in your last post.
35 deg Diamond is OK on mine.
Offline N4NV
  •  398 398
Re: LazyTurn
« Reply #986 on: April 04, 2009, 06:33:57 PM »
Overloaded, I downloaded the Lazycam update before you even posted.  I installed it and now when I run LazyCam it says I am running version 3.00.  When I run the Lazyturn exe file, I still get the same error.  I rebooted the computer and it still does it.
Vince
Re: LazyTurn
« Reply #987 on: April 04, 2009, 06:54:10 PM »
RC,
TOOL INFO:
INSCRIBED CIRCLE=.76
UNCHECKED  FOR  USE TIP CENTER
TIP RADIUS=.016
FLANK CUT DEPTH=.379
CUT INFO:
CLEAR=0
STOCK CLR=.05
DEPTH / PASS = .05
What does your left side look like as that one has a radius in it and you would
get what your showing in your post #985.
Attached is the complete pic.
Re: LazyTurn
« Reply #988 on: April 04, 2009, 07:03:36 PM »
Vince,
I would recomend for Lazyturn that you run it iindependantly out of it's owne directory.
Use Mach to install Lazycam... only.... to say VinceLazyturn , then do the LazyCam update to that directory, then replace the exec with Art's latest version.
This way you won't affect the main MACH3 installation.
Re: LazyTurn
« Reply #989 on: April 04, 2009, 07:32:28 PM »
RC,
If you change the tool flank depth, stock clearance and depth per pass, from what i just listed,  I can get the paths to come out to what you show in reply 985.
That's why i posted the stuff about a preview of the tool to say a corner or straight line.
This way you don't need to keep making runs to see the effect, if that makes sense.
Although LazyTurn is easy , i believe most of the problems by users will be with the tools they
create. Just haven't figured out how to make it easy in the manual but working on it.
