Hello Guest it is October 30, 2026, 12:13:09 PM
Author Topic: LazyTurn  (Read 3620837 times)
0 Members and 10 Guests are viewing this topic.
Re: LazyTurn
« Reply #350 on: December 02, 2008, 05:47:16 PM »
Thanks Chip, as I added v3.041 back to the arsenal for viewing purposes.
sanalee,
 I don't think there is anything wrong on your side of the fence other than graphics display
between versions. I will only comment saying that it can be frustrating enough to go through your
 learning experience without this kind of issue to make it more complex.  Stay with us my friend as we
need the help.
 I just reloaded version 3.041 to a separate directory and opened a lot of turn files with no apparent issue.
 Rich
Re: LazyTurn
« Reply #351 on: December 02, 2008, 05:59:49 PM »
Sanlee
 change the IJ mode on the general configs page in Mach.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: LazyTurn
« Reply #352 on: December 02, 2008, 06:38:31 PM »
Hi, Hood
That should fix it for him, That's the second time I've forgotten about the I,J's setting in general configuration menu.
The Little crop cir's with (Turn Options) Reverse Arc's in Front Post and the Big crop cir's in General Configuration menu.
Thanks, Chip
Re: LazyTurn
« Reply #353 on: December 02, 2008, 08:41:58 PM »
Hi Art,
Just some general comments but specific are noted in red on the attached JPEC image.
- Depth per pass is not saved but did save in one of the versions
- Can the file name be saved in the posted gcode so that you don't have to edit to add (  )?
Other comments noted on the jpeg.
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: LazyTurn
« Reply #354 on: December 02, 2008, 09:03:28 PM »
interesting..
Re: LazyTurn
« Reply #355 on: December 02, 2008, 09:42:34 PM »
ART,
It is doing the same thing on the base which is similar to the upper profile of the candlestick.
Hey, 4 bad lines / 1300 lines x 100= .077% error..... getting close to 0%
Could manualy edit these lines but would be a PITA.
see attachments and code
Offline ART
  •  1,703 1,703
Re: LazyTurn
« Reply #356 on: December 03, 2008, 09:53:26 AM »
Hi Guys:
  Heres a new version that trys to fix some of those errors. (thx for the files, they helped allot.)
 There is also a diags mode in the rough dialog, you cant post if you use it, but the resultant image is helpfull to me to find where some types of
errors come from. Its also a very fast way to see a line reduction of the image. No gouging tests are done, and tool geometry is not considered
in this case, also no real toolpath is calc'ed, it just shows the "before pathing" data from the path engine. Generation of the scan lines is done in an
iterative algorithm, so the "diags" output can show me if that is working OK, it was failing in the test files provided.
(Stock rotation is temporarily disabled as well in this version.
Art
Re: LazyTurn
« Reply #357 on: December 03, 2008, 11:14:12 AM »
Hi ART,
  Stock rotation still works.
Did you mean TOOL rotation ?
LOOKING GOOD !
Thanks so far,
RC
Re: LazyTurn
« Reply #358 on: December 03, 2008, 11:16:30 AM »
Hi Rich,
 For now, you can leave the Prolog box empty. No need to edit the ( ).
All ready for York ?
See Ya,
RC
Offline ART
  •  1,703 1,703
Re: LazyTurn
« Reply #359 on: December 03, 2008, 12:43:30 PM »
Rich:
 No, I meant stock. While the job profile is still spun, the stock is no longer shown, ( its the profile above the piece..
Art
