Hello Guest it is October 21, 2026, 04:40:09 PM
Author Topic: Angular short rotation on G0 question??  (Read 11190 times)
Offline Tarak
  •  229 229
« on: February 11, 2008, 04:58:48 PM »
Is it possible to Angular short rotation on G0 for just G90 not G91 aswell?
I don't see the purpose if you are using incremental why you would need it, it defeats the purpose of incremental........doesn't it.....or am I missing the point?
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
Re: Angular short rotation on G0 question??
« Reply #1 on: February 13, 2008, 01:44:22 PM »
The answer is yes - if you check it out on an unconected PC. I haven't had a real play with it, but on G90 it goes the shortest way to the required position. On G91 the move is incremental to the posiition you are at so moves in the 0 - 180 bracket move you forward, moves in the 180 to 360 bracket move you in reverse. However - say you are at 10 degrees - G0 A10 moves you to 20, G0 A350 moves you to 0.
Is there something deep in that - or could you just use G0 A-10 instead
