Hello Guest it is October 31, 2026, 12:56:41 PM
Author Topic: Parker OEM750 stepper and mach3  (Read 11445 times)
« on: February 10, 2008, 05:08:21 AM »
Hi.!
can you help me please?
If you see the wiring diagram (OEM750 Inputs and Outputs (page 29 from 100)
http://www.compumotor.com/manuals/OE...tire_Rev_B.pdf
can you tell me if this drive will work with Mach 3 ??
If yes can you tell me the wiring?
thanks a lot!
George!
Offline chad
  •  361 361
  • When the going gets weird, the weird turn pro.
Re: Parker OEM750 stepper and mach3
« Reply #1 on: February 14, 2008, 11:57:46 PM »
That link is bad.
I will take a look when i can.
Chad
« Reply #2 on: February 16, 2008, 03:13:42 AM »
I am using a OEM 750 on my 4th axis right now. Does yours have the indexing card installed? If so it needs to be removed and jumpers put in place of the card. The card is by the db25 connector and mounts to the board by a header and just pulls off. You may have a hard time finding jumpers as the pins are odd spaced. I ended up finding a matching socket and soldering the pins shorted to make a header.
