Hello Guest it is November 02, 2026, 02:50:04 PM
Author Topic: Setting my Limits  (Read 13519 times)
Setting my Limits
« on: February 04, 2008, 04:33:36 PM »
I have all my limits set to pin 13.  5 volt input. When I set to active high, my limits do not work. When I set my limits to active low, like my home switches, I cannot reset the E stop.
My limits are in series that when the switch trips it breaks connection. Help!
Re: Setting my Limits
« Reply #1 on: February 04, 2008, 04:50:21 PM »
Do you have the correct port asigned for them?
« Reply #2 on: February 04, 2008, 05:24:37 PM »
Yes,
I'm sure. Even set them automatically.
« Reply #3 on: February 04, 2008, 06:21:50 PM »
OK so how are you connecting to the port? do you have a breakout board or is it direct? If its a Breakout what make? What exactly do you mean by "Pin 13. 5v Input"?
« Reply #4 on: February 05, 2008, 05:47:51 AM »
Breakout board C1 by CNC4PC. Output 13 where you jump the output to produce 5 volts. I use pin 10 output for my home switches the same way and they work perfectly.
