Hello Guest it is November 13, 2026, 09:36:51 AM
Author Topic: z starts down but x and y are already moving  (Read 13212 times)
« on: January 29, 2008, 11:02:11 AM »
hi I'm Foxy, first time on and I have a stupid problem I am trying to do some engraving and what happens is that it goes to x and y and z starts down but x and y are already moving so cut depth is like a lead in it must be simple like me any help
Foxy
« Last Edit: January 31, 2008, 05:38:47 PM by Hood »
« Reply #1 on: January 30, 2008, 04:03:35 AM »
Foxy,
G code is line logigal. If you put X, Y, Z values on one G0 line Mach will execute them all at the same time. To do what you want, you need to do  G01 Z (Value) F (Value) This will feed Z into the material, then on the next line G01 X (Value) Y(Value) F (Value), this will cut from your starting point to the new X,Y.
Ask again in the Mach General Discussion forum if this isn't clear.
Ian
« Last Edit: January 31, 2008, 04:05:48 PM by Ian Ralston »
« Reply #2 on: January 31, 2008, 12:31:53 PM »
HI THANKS FOR THAT I SORT OF UNDERSTAND NOW, DO YOU HAVE TO PUT THE FEED RATE ON EVERY LINE
FOXY
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #3 on: January 31, 2008, 01:31:35 PM »
No, just every time you want the feed to change.
Graham.
« Reply #4 on: January 31, 2008, 04:05:00 PM »
Foxy,
Certain G codes are "modal". This means that when you use them, they remain at that value or mode until changed or cancelled. Feed rate "F" is one of them. Now you know the magic word, search in the manual for the list of modal commands.
Ian
