Hello Guest it is November 24, 2026, 04:12:11 PM
Author Topic: SetDro(0 ,GetDro(0)/2) in BrainControl  (Read 46449 times)
Re: SetDro(0 ,GetDro(0)/2) in BrainControl
« Reply #10 on: January 30, 2008, 05:21:27 PM »
that wont work since you need to start at zero, also as your first equation keeps adding up, only the value of 1, will give you a half value after that your dro value is climbing to no change at 2, and it continues to climb in multimple of the original value.......
scott
« Reply #11 on: January 30, 2008, 05:45:39 PM »
sry - i don't understand what you mean
can you give a sample ?
Frank
« Reply #12 on: January 30, 2008, 05:58:41 PM »
his original post, as I understand it, he wanted a singlular input that each time you push it, (and it starts at zero value).
Then when he pushes the button the first time, the X axis current value is divided by 2 and then reposted into the X position dro.
When he incremnts by pushig the button again the Y axis value is cut in half and then reposted to the Y dro.
next press (value is now 3), does the Z, at value higher it then resets everyting back to zero w3ith standard "true" axzis positions.
Since theser are temporary, I dont understand why scaling wont work for him since it would do exaclty that.
scott
« Reply #13 on: January 30, 2008, 06:02:35 PM »
ah ok
i have taken his last words of the first post:
I only want to divide a Dro Value when some Input Signal comes in.
and thats what the brain do
Frank
