Hello Guest it is November 17, 2026, 11:21:58 AM
Author Topic: Startup/Shutdown signal for Compumotor/Parker Zeta controller  (Read 11101 times)
« on: January 25, 2008, 09:47:24 PM »
I am looking for a way to turn the Compumotor/Parker Zeta controllers on and off then Mach3 program starts and terminates, similar to the Charge Pump signal for Gecko drives. However, the Charge Pump is a high-frequency signal, while I need just constant +5V to any output pin (1, 14, 16, or 17) when the Mach3 program is running.
Victor
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
Re: Startup/Shutdown signal for Compumotor/Parker Zeta controller
« Reply #1 on: January 26, 2008, 03:14:07 AM »
If your computer is dedicated to Mach 3, then just take a signal from the 5 v dc line so when the computer is turned on the Compudrive turns on.
If not, and you use the computer for other things, then use one of the axis enable outputs - I dont think it matters which one but they are certain to be "on" when running Mach3 - even if you are not using them.
