Hello
Guest
it is
November 01, 2026, 10:03:11 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
LazyCam (Beta)
Rotating Drawing
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Rotating Drawing (Read 11145 times)
Jim Neifert
56
Rotating Drawing
on:
January 24, 2008, 09:27:06 AM »
I have LC 3.00.2 Lic version, I can't get the drawing to rotate so I can see the cut lines. I have a 3 button mouse, just wondering if there is a special setting the 3rd button, or wheel in my case should be set at. Right now if I press the wheel down it gives a enter command.
I have held it down and moved it all over the drawing, still does not rotate it.
Any ideas why?
Jim
Logged
Chip
2,055
Gainesville Florida USA
Re: Rotating Drawing
Reply #1 on:
January 24, 2008, 12:52:05 PM »
Hi, Jim
Look in Windows, Start, Control Panel, "Mouse", Hardware, Properties, Advanced Settings, Check/Select "Wheel Detection" is set to "Assume wheel is present".
You'll be prompted to Restart Windows, Using Win XP hear.
Hope this Helps, Chip
Logged
Jim Neifert
56
Reply #2 on:
January 24, 2008, 01:48:10 PM »
Thanks Chip
Under properties I have no advanced settings tab, mainly because I use a Microsoft cordless mouse, and that might be the problem. The wheel works with other programs, just not with LC.
Its not that I have to have that function, just couldn't figure out why it won't work.
Jim
Logged
Chip
2,055
Reply #3 on:
January 24, 2008, 03:10:15 PM »
Hi, Jim
Maybe it's the Driver, Is it ps/2 compatible mouse, Tried changing the driver, Updating it. ?
Thanks, Chip
Last Edit: January 24, 2008, 03:13:00 PM by Chip
Logged
budman68
2,352
Reply #4 on:
January 24, 2008, 04:33:22 PM »
Jim, if you have a microsoft mouse, it should have been setup for the "auto scroll" function when installed. That is when you push down on the mouse wheel, a cursor comes up with arrows and when you push the mouse up it auto scrolls upward and when you pull the mouse down, it scrolls downward. Does you mouse have the label on the bottom? What exactly is it called?
Some have a special software program that enables different functions to the buttons.
Logged
Dave->
Print
Pages:
1
Go Up
« previous
next »
