Hello Guest it is November 10, 2026, 07:34:55 PM
Author Topic: OMAG Stone/Granite mill retrofit..........  (Read 33360 times)
Re: OMAG Stone/Granite mill retrofit..........
« Reply #10 on: October 24, 2008, 10:52:33 AM »
Thank you,
BTW: Very nice "Stang" in your avatar pic............ My 15y/o son would probably donate a testicle to own one like that.........
scott
« Reply #11 on: November 29, 2008, 07:35:18 PM »
Hi Scott.
Sorry to hear about your work experience.  I too have had the same thing happen to me.  Only I was on the other side building and deigning the machine and being told that I would get to build all the frames for a stone router.  After I designed and built the first three I was told they were giving up the project only to see my frame on their web site and learning they took my work and found a cheaper shop to build them.
But I do have a question for you.  What motors and drives were you able to make work with  Mach.  A machine that size would need Servos.  I am building a small five axis machine and I need to use servos on it.  Not sure if Mach can do a machine like this but I am going to give it a try.
« Reply #12 on: December 08, 2008, 08:11:25 PM »
^^ Have you seen some of the videos of machines controlled by Mach3 here? http://www.youtube.com/groups_videos?name=artsoft
